Rounding over binding edges. http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=1385 |
Author: | Dave Rector [ Fri Mar 18, 2005 6:05 am ] |
Post subject: | |
I was sondering how most of you go about rounding over the edges of your bindings to take that sharp edge off. I've been just using a scraper or small sanding block and it seems like the result is not as consistant as I would like it to be. I also saw a tiny roundover bit for a dremel type tool and was wondering if that would be too much radius. I think it was a 1/8 radius, but you wouldn't have to set it as low as it will go, just enough to take the edge off. It seems like it would be easier to get a consistant profile all the way around this way. |
Author: | Brock Poling [ Fri Mar 18, 2005 6:26 am ] |
Post subject: | |
woodcraft carries a 1/16" round over bit, but I think even that might be too much |
Author: | Dickey [ Fri Mar 18, 2005 6:37 am ] |
Post subject: | |
Steidl? |
Author: | Dave Rector [ Fri Mar 18, 2005 8:35 am ] |
Post subject: | |
Is everyone else just using sandpaper or a scraper, as I have been doing? Or is there a better way to do this? Guess that's what I should have asked. Sorry, no sleep for a couple of days. |
Author: | Josh H [ Fri Mar 18, 2005 9:19 am ] |
Post subject: | |
I use my router. I can't remember if its a 1/8 or 1/16 bit that I use. I go back after and touch it up with a sanding block. It's a fast and fairly consistant method for rounding the binding. Josh |
Author: | Sprockett [ Fri Mar 18, 2005 9:25 am ] |
Post subject: | |
I use sandpaper and a scraper, when the guitars that close to being the last thing I want to get near it is a power tool.... It only takes a few minutes to do. -Paul- |
Author: | npalen [ Fri Mar 18, 2005 9:50 am ] |
Post subject: | |
Dave--Get some sleep, for crying out loud! Nelson ![]() |
Author: | LouisianaGrey [ Fri Mar 18, 2005 9:54 am ] |
Post subject: | |
Yup, scrape and sand does it every time. |
Author: | Bobc [ Fri Mar 18, 2005 10:17 am ] |
Post subject: | |
I turn a hook on a single edge razor blade. Makes a nice little cabinet scraper. |
Author: | Tim McKnight [ Fri Mar 18, 2005 11:13 am ] |
Post subject: | |
I used to do it by hand with the various methods above but wasn't happy with the inconsistency. I now use a lam trimmer and round-over bit with a guide bearing. I'm guessing it's a 1/4" which is a 1/8" radius. I just set it to just kiss the sharp edge off and then finish up with 220 by hand. Place a mark on the top at each edge of the finger board location and don't do that area or you will have an ugly gap when you mount the FB. You want to leave that area square. Don't ask how I know that ;( |
Author: | stan thomison [ Sat Mar 19, 2005 1:29 am ] |
Post subject: | |
Just kissing and rounding a small amount with paper or scraper. Just stay away from area of neck joing as you get a gap. I know that for sure. since just taking off sharp edge doesn't need power tools |
Author: | Dave Rector [ Sat Mar 19, 2005 1:31 am ] |
Post subject: | |
Tim hit the nail on the head. I'm not looking for the easiest way, just the most consistent. Guess I'll stick to the way I'm doing it for now. |
Author: | npalen [ Fri Mar 25, 2005 5:11 pm ] |
Post subject: | |
I used to see a tool in some of the supplier catalogs for rounding corners. It looked similar to a beer can opener (church key for you old timers) Might be worth a try for rounding the binding edge. Has anyone seen this in any catalogs recently? Thanks Nelson |
Author: | Mattia Valente [ Fri Mar 25, 2005 7:32 pm ] |
Post subject: | |
I think Lee Valley still stocks the things. You mean these things here, by any chance? |
Author: | tippie53 [ Fri Mar 25, 2005 11:23 pm ] |
Post subject: | |
I agree not to use power tools. the back and top actually are not flat and the radius is easy enough with a touch of sandpaper and a little steel wool. Don't make things harder than they are. Simplicity is the key |
Author: | npalen [ Sat Mar 26, 2005 12:43 am ] |
Post subject: | |
Thanks, Mattia! I find that a consistent radius on plastic binding is time consuming. Seems like it just doesn't sand as nice as wood. May have to give one of these a try. Nelson |
